Success!!! & Opinion on some Codes
Old Sep 5, 2013 | 01:36 PM
Phatrowles's Avatar
Default Success!!! & Opinion on some Codes
Hey Guys,
First of all I want to say thank you to all y'all for helping me work through some Starting issues that were successfully resolved... it was the Crank Shaft Position Sensor! Thanks!
I also just an Ultragauge, and it rocks.
However, It immediately gave me some new readings on Trouble Codes and Pending Trouble Codes that I wanted your opinion on. Mind you that the CEL was not on.
P1590 - I am notified of this every minute or so while driving until I suspend the alarm.
Pending codes:
P1171 pending
P1174 pending
What do you guys think?
Old Sep 5, 2013 | 04:18 PM
Some pending codes appear, then don't occur again and eventually drop off. A number of codes require 2 or 4 "happened agains" to turn on the CEL.
Old Sep 5, 2013 | 04:23 PM
1590 - three amigos riding hard to catch up with you.
1171 / 1174 - ECU has adjusted as far as it can for variations in what is computed for fuel mix and what is actual. Look for vacuum leaks past the MAF sensor (un-metered air). Always good idea to check air filter, clean out PCV system, throttle body. If cleaning MAF use a made for MAF spray only when cold.
Old Sep 6, 2013 | 08:42 AM
Phatrowles's Avatar
Thanks Savannah!
Damn those amigos... : )
This ultragauge business is pretty slick though! No wonder everyones nuts about them!
Old Sep 6, 2013 | 10:42 AM
IIRC we have Spike to thank for the dash mount obsession - and a gallon bottle of Malox should come with each one, to calm your stomach.
Old Sep 6, 2013 | 08:54 PM
Jared9220's Avatar
I had the same codes. You might want to take a took at this thread I made. https://landroverforums.com/forum/di...s-cigar-54235/
Old Sep 7, 2013 | 12:35 AM
Phatrowles's Avatar
thanks a ton, im all over it!
wolfgang528
Defender
Dec 28, 2010 04:25 PM
Sfef84
Apr 7, 2008 10:07 AM
GregHaugen
Dec 21, 2006 11:08 PM
