Suddenly, a litany of trouble codes?
Old 03-24-2015 | 06:18 PM
KlamathMatt's Avatar
Default Suddenly, a litany of trouble codes?
Driving yesterday, the check engine light came on and one code came up - 0161 (o2 sensor) came on. Re-set it and check engine light came on again today with a bunch of different codes (P1884, 0102, 0445, 0448, 0340, 0134, 0154). After i drove to lunch todya, I re-set those codes, and I got a the codes plus a couple additional codes ~0135, 0155. So now I have nine codes in total - -where do I begin -- how do begin to tackle this issue?
PS
Upon turning the ignition, the engine fires right up - but I have noticed today a slight -- slight - hesitation. Not sure if that suggestiive of anything either.
Many thanks!
Matt
Old 03-24-2015 | 06:32 PM
jobooth's Avatar
Sounds like you might need some new O2 sensors. Fuses all ok? Check the O2 sensor connections. The front passenger one tends to get gunked up with oil.
Old 03-24-2015 | 09:50 PM
jfall's Avatar
Bro,
http://enginecodemaster.com
can d-code da code.
Put in codes from the Rave CD.
Old 03-28-2015 | 06:34 PM
Default A bunch of "circuit" codes - where would you begin?
Started the day with 9 codes, got 3 more to sort out. They all have something to do with circuit issues.....what should I do?
I have noticed more and more hesitation/difficulty when starting the engine.
P0448 = EVAP system vent control circuit shorted
P0102 = Mass Airflow Circuit - Low Input
P0340 = Camshaft position sensor circuit malfunction Open/short circuit to vehicle supply or earth.
Old 03-28-2015 | 07:04 PM
abran's Avatar
I'm going through something similar. Changed the camshaft position sensor, crankshaft position sensor, and the mAF. No change. I will start a thread once I get a chance, but I think I have some frayed wires somewhere.
Matt_Attack352
01-13-2014 09:55 AM
Fireman
11-23-2010 01:53 PM
jmrover
10-20-2007 05:05 PM
johnkbl
09-16-2007 06:09 PM
profesrgeo
Freelander
09-16-2006 05:40 PM
Quick Reply: Suddenly, a litany of trouble codes?
