Sun roof two stage opening QUESTION
Old Apr 16, 2022 | 01:55 PM
colinp007's Avatar
Question Sun roof two stage opening QUESTION
I have just re-sealed the sunroofs on my 2000 TD5 D2. All back in okay but the front one that I removed no longer has the two stage opening (tilt then fully open). It will open and close okay but you have to hold the button. I have heard that you may need to calibrate the sunroof but cannot find out how. Have I done something else wrong? Any ideas most welcome. Thanks in advance.
Old Apr 16, 2022 | 08:14 PM
Extinct's Avatar
Remove the motor from the frame while leaving connected push button, one direction it will stop as soon as released, the other it runs till it gets to home. Make sure sunroof is fully closed when doing procedure
Old Apr 17, 2022 | 11:09 AM
colinp007's Avatar
Thumbs up
Thanks for that it helped a lot. I can now see the position of the red plastic cam on the motor is critical. All fixed.
tomasboman
Jan 13, 2022 11:06 PM
Darla123
Nov 6, 2015 01:55 PM
Disco-Nate
Sep 17, 2009 07:49 AM
raj49
Jan 6, 2009 06:27 PM
roving patrol
May 20, 2008 01:53 PM
