sunroof
Old Feb 28, 2010 | 04:31 PM
jrm123180's Avatar
Default sunroof
Hi,
I'm having issues with my FRONT sunroof, it won't open. It DID work a year ago before parked, but now I can't get it to do anything. When I push the button, I do hear it attempt to try and work but NOTHING at all. The rear seems to function with out any issues...any suggestions?
Old Feb 28, 2010 | 04:37 PM
What year?
Old Feb 28, 2010 | 04:52 PM
jrm123180's Avatar
sorry, it's a 2003
Old Feb 28, 2010 | 04:53 PM
Sorry but I dont know then.
Other than the motor or tracks are now seized.
Old Feb 28, 2010 | 10:49 PM
BajaXJ92's Avatar
Just dealt with this same problem today on my '96.
First thing to do is check your fuses.
My front sunroof motor died recently. I would recommend just to save yourself the money, pulling your rear sunroof motor and plugging it in to your front sunroof. Cycle it and make sure it works. If it works, your motor is bad. If it doesn't there may be an issue with your sunroof ECU being cracked, which should be an easy fix.
Report back.
Edit: If your sunroof hasn't moved in a while, the bearing in the motor may be seized slightly. If you pull the motor down and simply cycle it without load on it, it may free it up. I had two spare motors laying around today when i replaced my front motor. One of them hadn't been cycled in quite a long time and struggled the first couple of times that I tried it. If you do remove the motor, keep it plugged in and give it a little bit of help before you write it off as bad, it may just be slightly siezed due to lack of use.
Old Mar 3, 2010 | 07:16 PM
jrm123180's Avatar
so I pulled the motor out and opened it up and it was all rusty inside. I freed it up and have it working fine now.
Thanks for your help.
Steve
Old Mar 19, 2010 | 05:26 PM
Rover601's Avatar
3rd Gear
Default Identical Problem
Saw your guys post. I have a 02 and front sunroof won't open but rear will. Same fuse runs front and back right? Shouldn't be the fuse. Where are the motors at and how do I get to them? Sorry I have to ask I just don't know. Thanks for the help.
Old Mar 19, 2010 | 05:30 PM
AAP's Avatar
AAP
Have you downloaded the Rave Manual yet? Great place to start.
http://www.landroverresource.com/
BigRed98
Jun 21, 2010 12:30 AM
opus13
May 18, 2006 05:07 AM
Durfee
May 11, 2006 04:50 PM
Jesse
Mar 2, 2006 01:53 PM
funkeruski
Aug 22, 2005 02:26 PM
