Sunroof drains
Old Sep 7, 2018 | 10:06 AM
Ben Matheson's Avatar
Default Sunroof drains
Can the drains be seen from the roof with the sunroof open? Rear is leaking and wanted to inspect for cracks. Hoping the heqdlihea doesn't have to come off to inspect
Old Sep 7, 2018 | 10:23 AM
Richard Gallant's Avatar
Not really you can kind of see them but that is it
Old Sep 7, 2018 | 10:30 AM
Red5's Avatar
No, not from the top. At least not well enough to assess the problem. You could probably remove the trim around the hole on the inside and pull it down enough to see the drains. Wedge a socket or something in there to hold it down and soak the roof with the hose to check for leaks.
Likely the sealant between the plastic drain corners and metal tray has failed. The liner has to come out for any kind of repair though.
Old Sep 7, 2018 | 02:38 PM
tcr6v1's Avatar
Headliner has to come off. I'm actually doing this repair now if you need any pictures
Old Sep 9, 2018 | 03:31 PM
OffroadFrance's Avatar
Unlikely to view but an illuminated borescope may sot any issues. Do a water test and check the drains underneath and the cups in the frame with the borescope. You may need to remove the headliner if the rear sunroof is leaking as it might be the upper peripheral mastic and rubber seal. Do both the front and rear seals also along with reinforcing the plastic drain wells.
Old Sep 9, 2018 | 07:51 PM
Probably would help. I cleared the drains and thought I was good but it rained tonight and water is dripping out of the rear ac vents
Old Sep 10, 2018 | 03:42 PM
tcr6v1's Avatar
The seals where the sunroof meets the roof like to disintegrate. Take the headliner out like you normal would (it's not that hard at all, just make sure you have a plastic panel clip tool so you dont damage panels.) Now the points of leakage are usually either the drain tubes breaking off or the seals.
There is no point in taking the headliner off and only fixing addressing one of the issues. I highly recommend you do the following:
make sure you buy a nice high quality silicone. Buy a tube and use it in a caulking gun for better control.
1) remove both sunroof trays (held on by a bunch of T20 torx screws
1a)make sure tubes arent clogged by blowing into them
2)remove all silcone from where the metal tray meets the plastic piece where the tube attaches
3)if the nipple is broken off you can epoxy it back on with JB weld or similar
4) re silcone where the tray meets the plastic part. Make sure to do this well and do both sides.
5) remove both sunroofs. This is easy as they are only held on by the trays. With the tray removed push up on the sunroof and what's ever left of the factory seal should give out.
6) remove all leftover of seal material from both the sunroof and the roof
7)run a nice bead of silicon around the lip of the sunroof assembly. Not too much but not too little
8) reinstall sunroof assembly being careful not to make a mess
9)reinstall sunroof tray
10)reinstall everything related to headliner
REMEMBER... Most silicones take 24hrs to cure. Make sure you do this when the forecast doesnt call for rain.
Old Sep 11, 2018 | 07:25 AM
Thanks good clear instructions and I guess I need to just do it right the first time
Old Sep 12, 2018 | 10:41 AM
Motorhead1's Avatar
https://landroverforums.com/forum/di...al-tips-82723/
I posted a few pics of how I did mine. I don't go into detail on how to completely remove the sunroof, but I just wanted to show you can do this job WITHOUT disturbing the plastic drains. Usually the drains are the culprit, but not always, as was my case with my rear sunroof.
Jadden14
Dec 23, 2017 01:49 PM
etsZac
Feb 6, 2014 06:22 PM
jalodge
Oct 3, 2013 05:27 PM
Gerard
Feb 21, 2011 02:03 PM
