Sunroof and headliner
Old Nov 29, 2016 | 03:20 PM
OffroadFrance's Avatar
Well worthwhile.
Whilst the headliner is out and you've solved your sunroof leaks, if you live in a really hot area/state a good tip is to install some hi performance alu foil coated thin insulation (20mm thick) above the headliner, this stops radiated heat into your cab. Be careful though where you have exposed electrical connectors as both sides are alu sheeting and liable to cause a short circuit or fire. Use heat shrink electrical insulation on these connectors before installing the main alu foil insulation.
HeadlinerExpress
Jul 2, 2020 08:47 AM
aftermath431
Sep 30, 2013 09:28 PM
KOz
Appearance & Camping Set Ups
Mar 20, 2013 06:07 PM
rbelz
Nov 21, 2007 05:36 PM
Old School
Jan 10, 2007 08:20 PM
