sunroof leak, cruise control
RE: sunroof leak, cruise control
The end of the tubes cannot be seen from underneath but the frontend up right around the front mud flaps. Search this forum and you will find pics of the tubes as they run down the body. There you will see the rear tubes. I keep mine blown out and the seal clean with silicon spray. Been to the car wash twice and still dry. I have blown mine out several times and my hoses are still connected. Did you talk to the dealer about the leak and if they found anything when they had it opened up?
Im not sure about that Mike. The dealership that I used to take it to closed so the new land rover dealership will only cover the cost of the part if that is what in fact failed and is causing it to leak again. Land Rover will only cover thepart for oneyearnow that it is out of factory warranty! What a bunch of BS! I even called corporate Land rover and complained that they never fixed the real problem in the first place, and they told me they would only cover the cost of the part ifthat is whatfailed. I dont know if im getting screwed because the dealership i had do the repair under warranty closed, or if they have a shady parts/labor warranty! i had a similar scenario with mya Mercedesand because they had the issue reported and repairedand then the same problem withinthe yearthey replaced something else to fixiteven when it was out of factory warranty (parts and labor).
Evan5291
11-21-2017 07:59 AM
southfloridadiscoII
06-28-2009 11:03 PM
cosmiccharlie79
06-16-2008 09:13 AM
