sunroof leak, cruise control
Old Dec 24, 2007 | 01:58 PM
Default RE: sunroof leak, cruise control
The sun roof repair that dealer did is covered for 1 year, so go back and see the dealer.
Old Dec 24, 2007 | 01:59 PM
willstevens's Avatar
The end of the tubes cannot be seen from underneath but the frontend up right around the front mud flaps. Search this forum and you will find pics of the tubes as they run down the body. There you will see the rear tubes. I keep mine blown out and the seal clean with silicon spray. Been to the car wash twice and still dry. I have blown mine out several times and my hoses are still connected. Did you talk to the dealer about the leak and if they found anything when they had it opened up?
Old Jan 1, 2008 | 07:07 AM
howellja's Avatar
Im not sure about that Mike. The dealership that I used to take it to closed so the new land rover dealership will only cover the cost of the part if that is what in fact failed and is causing it to leak again. Land Rover will only cover thepart for oneyearnow that it is out of factory warranty! What a bunch of BS! I even called corporate Land rover and complained that they never fixed the real problem in the first place, and they told me they would only cover the cost of the part ifthat is whatfailed. I dont know if im getting screwed because the dealership i had do the repair under warranty closed, or if they have a shady parts/labor warranty! i had a similar scenario with mya Mercedesand because they had the issue reported and repairedand then the same problem withinthe yearthey replaced something else to fixiteven when it was out of factory warranty (parts and labor).
Evan5291
Nov 21, 2017 07:59 AM
Juergen33911
Jun 19, 2013 12:49 PM
BigRed98
Jun 21, 2010 12:30 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
cosmiccharlie79
Jun 16, 2008 09:13 AM
