sunroof leaks
sunroof leaks
i have a question wondering if onyone can help with ideas well any time the dsico sits i get leaks through both sun roofs. when i stop the water runs out the front seat belts and the switch in the rear seat for the rear sun roof. could this be the traps that the water runs out maybe clogged?
any ideas would be appreciated?
thanks
jason
thanks
jason
on
thagremlin (03-12-2023)
Yup
I had the exact same problem, down to the waterfalls coming out of both front seatbelt posts. I had compressed air blown in the drain holes, did nothing. Turned out the driver's side drain tube connector attached to the front sunroof tray was sheared off. Had it epoxyed and has held since.
The easy way to test is to open the front roof and pour a small amount of water in the tray. As soon as you see water in the cabin, the problem has been confirmed.
The only way to fix it is to drop the headliner and get to it. Royal pain.
write up comming
I just took out my daughters headliner today as it was getting to be a swamp fest inside her truck.... I will be doiing a how to and why....tommorow.. Took pics to make it easy.I just did the first coat of RTV and will be doing another one tomorrow. Then water test...well, its suppose to rain here tomorrow like everyday this time of year. The leaks i found and there was 3, where all sunroof drain basins.Not the pipes that always break but the basins. Took about a hour or so to pull the headliner. Used the how to here on the board and a couple tricks to add to it.
ruggles
02-12-2011 08:46 AM
