sunroof leaks
Old Sep 5, 2010 | 11:11 PM
2000discoIIguy's Avatar
3rd Gear
Post sunroof leaks
i have a question wondering if onyone can help with ideas well any time the dsico sits i get leaks through both sun roofs. when i stop the water runs out the front seat belts and the switch in the rear seat for the rear sun roof. could this be the traps that the water runs out maybe clogged?
any ideas would be appreciated?
thanks
jason
Old Sep 6, 2010 | 07:24 AM
Start by checking for clogged sunroof drains.
Open each sunroof and look for the drain, a small tube in the front? corner of each sunroof.
Old Sep 6, 2010 | 09:31 AM
As Spike has mentioned, need to get all 4 tubes blown/cleaned out. If that doesn't fix it then you will need to have the headliner dropped and look for a break at the connection or a disconnected drain tube.
Old Sep 6, 2010 | 10:05 AM
3rd Gear
Cool thanks guys I will have to take a look at it tonight!
Old Sep 9, 2010 | 09:36 PM
Thor1's Avatar
Lightbulb Yup
I had the exact same problem, down to the waterfalls coming out of both front seatbelt posts. I had compressed air blown in the drain holes, did nothing. Turned out the driver's side drain tube connector attached to the front sunroof tray was sheared off. Had it epoxyed and has held since.
The easy way to test is to open the front roof and pour a small amount of water in the tray. As soon as you see water in the cabin, the problem has been confirmed.
The only way to fix it is to drop the headliner and get to it. Royal pain.
Old Sep 9, 2010 | 10:26 PM
vandev's Avatar
Default write up comming
I just took out my daughters headliner today as it was getting to be a swamp fest inside her truck.... I will be doiing a how to and why....tommorow.. Took pics to make it easy.I just did the first coat of RTV and will be doing another one tomorrow. Then water test...well, its suppose to rain here tomorrow like everyday this time of year. The leaks i found and there was 3, where all sunroof drain basins.Not the pipes that always break but the basins. Took about a hour or so to pull the headliner. Used the how to here on the board and a couple tricks to add to it.
Old Sep 10, 2010 | 08:53 AM
nosup4u's Avatar
looking forward to seeing that write up, i will be pulling my headliner shortly to fix leaks and install new fabric.
Old Sep 11, 2010 | 08:32 PM
wrp's Avatar
wrp
I spent lots of time trying to fix the leak in the rear sunroof, until I broke a plastic fitting. Then I simply caulked the glass roof permanently shut, and have not had a leak in the past year.
Old Sep 12, 2010 | 06:47 AM
vandev's Avatar
Default good advice
good advice....i fixed 3 leaks only to find 2 others so i will be doing that today..... POS
Spencerfitch
Sep 27, 2020 12:17 PM
FlyingZebra34
Apr 22, 2013 12:07 AM
discoboy
Dec 20, 2012 02:24 AM
ruggles
Feb 12, 2011 08:46 AM
Gerard
Feb 17, 2007 05:33 AM
