Sunroof leaks repaired
Old Apr 6, 2022 | 09:59 AM
adalton's Avatar
Thumbs up Sunroof leaks repaired
For anyone dealing with sunroof leaks!
I was dealing with a large leak on my drivers side that would let water collect inside of the map pocket. I tried everything to fix it but nothing worked. Turns out the sunroof glass was not fully secured against the frame of the sunroof. After tightening down the bolts holding it on the leak is gone. After testing with a hose and 2 days of consecutive rain there is no water! Anyone dealing with a leak should try this before dropping the headliner.
Old Apr 6, 2022 | 02:23 PM
matt3502's Avatar
Thanks for this tip. I checked mine and all four could be tightened down. My problem with water usually comes when I have parked on a down slope with the front of the car facing down hill. Thanks again!
Old Apr 6, 2022 | 05:43 PM
Discorama's Avatar
I did that when installing new drain corners. The bolts were lose and the glass shifted backwards over time. From inside there was a gap between the glass and the rubber seal visible. After centering the glass (measure the gaps from above) and tightening the bolts the sunroof sealed properly again.
Wesc233
Mar 19, 2021 12:05 PM
series 1
Mar 31, 2012 07:45 AM
BigRed98
Jun 21, 2010 12:30 AM
marlymarl
Apr 12, 2010 02:00 PM
