Sunroof screw gears
Old Apr 5, 2020 | 11:46 AM
Frank4's Avatar
Default Sunroof screw gears
Anyone had them strip or no longer make contact with the gear on the motor?
I just installed a new to me motor, tested it before installation and I am getting nothing. When the button is pressed the motor goes for a few seconds and the sunroof glass does not move and I can tell there is no contact to the gears because there is no sound of binding of contact with anything. Just a free spinning motor. I compared the old and new motor gears and there is no difference in diameter and the screw gears don’t look chewed up.
The old motor was definitely making contact because before it went of completely the window would move slightly when the button was pushed.
Old Apr 5, 2020 | 04:44 PM
Extinct's Avatar
Swap front and rear, that will tell if you if it is the gearbox or the cables.
jamestfl
Apr 11, 2019 03:14 PM
philwarner
Sep 2, 2014 01:24 PM
alpinacsi
Oct 21, 2011 08:37 AM
mlelah
Freelander
Sep 3, 2011 03:02 PM
alanroberts50
Nov 18, 2007 11:56 AM
