Suspension "bang" on the front end.
Old Sep 6, 2018 | 04:21 AM
  #21
JUKE179r's Avatar
Originally Posted by Fallstaff
Opinions: on a scale of genius to finger loosing bat**** foolish...?
I've seen worse shade tree mechanic tomfoolery when I was in the military. but... make do with what you got and wear eye protection. lol
Old Sep 6, 2018 | 01:04 PM
  #22
The Deputy's Avatar
Not sure why you would be having so much difficulties? Just grab that shock tower and wiggle/pull it out of there and those springs should slide right in there, especially, if you have the hydraulic jack in place.
​​​​​​​ Brian.
Old Sep 6, 2018 | 02:13 PM
  #23
Best4x4's Avatar
OEM springs will indeed fall out once the shocks are loose, towers will come out, just wiggle em out, then the coil should pull out. You normally need the jack between the axle/frame only to install new coil springs.
Old Sep 6, 2018 | 02:20 PM
  #24
Fallstaff's Avatar
Me neither!
That shock tower doesn't want to come out without me bending either that lower AC line or the four brake lines coming out of ABS modulator. Neither of which seems like a good idea (I'll pick the AC of the two).
Perhaps someone replaced that AC line at some point and routed it wrong?
And I think with the spring its just that I'm doing it on the ground — when I look at the video he can get in there and wrestle it properly. I just can't get the leverage from the side.
I'll give it another shot later today and maybe post some shots if I can't figure it out.
Thank you all!
Old Sep 6, 2018 | 02:35 PM
  #25
Best4x4's Avatar
I noticed in the pic the shock isn’t connected to the tower. You can leave the 18mm top bolt in place, (only loosen the two 13mm shock bolts on the bottom, 4 shock tower 13mm nuts, then you simply grab the tower & the shock, pull it, twist it if needed and remove. AC Lines in the pic look normal.
I’ve done a lot of lifts with just hand tools, 2 jack stands, a LR bottle jack, and no coil spring compression tools, swaybars still connected, but I do loosen the rear ABS connectors, bracket, to give it more drop.
TaylorCadence
Nov 29, 2018 09:46 AM
ReRover
Jun 25, 2016 09:41 PM
Mp1976
Dec 10, 2014 01:30 PM
CANAMDiscovery
Mar 15, 2014 11:13 PM
kenk
Feb 15, 2010 09:51 AM
