Suspension, tires and lift question
Old 12-08-2008 | 05:10 PM
TD4141's Avatar
Default RE: Suspension, tires and lift question
Ok. Just bought a set of medium duty OME springs with a full set of Bilstein shocks. Next is saving some money for the tires and what size to choose.
Old 12-08-2008 | 05:14 PM
04BluDisco's Avatar
Anyone know the options available for keeping the SLS and getting a stiffer set of front springs?
Old 12-08-2008 | 07:50 PM
Willie 00D2's Avatar
I also have a 2000 D2. Stock springs. I am running 245/75/16 BfGoodridge A/T it is a great all around tire. Good in all condition's. For mud the BFGoodridge M/T is a good tire, also good for all conditions just a little louder. If you go with a mud tire you may want to have them siped.
Willie
Old 12-08-2008 | 08:10 PM
TD4141's Avatar
I've run the BFG A/T tires on some other trucks and they were pretty loud. I want this one to be more a road truck with the tires to go off road if needed. I'll be looking at tires pretty soon.
Old 12-08-2008 | 09:14 PM
Switzer's Avatar
Tread Wright MT-G tires.
www.treadwright.com
Cheers,
Pete
Old 12-08-2008 | 09:42 PM
discoxd's Avatar
with a 2" lift you can run a 265/75-16 tire... you will have to do a little trimming on the rear quarter panel just behind the rear tire (where your mudflaps would be) and you may have a little bit of rubbing when you turn your steering wheel to full lock in either direction... but it is a very common tire size that most manufacturers produce tires in... i'm actually goin pick up a set of bfg mud terrains on wednesday in that size for mine...
Old 12-09-2008 | 07:03 AM
TD4141's Avatar
Switzer. Thanks for the link. How do you like the tires? Are they loud on the road? I never thought about retreads. I just never trusted them for anything.
discoxd. I dont want to cut or rub anything so I will be staying with the 245 you suggested. I am guessing that it is a bigger tire than I have since my 255 doesnt look as big as some of the pictures I've seen with 245's.
I'd like to see some good pics of a standard height truck with the 245 tires.
Old 12-09-2008 | 08:39 AM
discoxd's Avatar
stock height (worn out sagging suspension) with 245/75's... this was right when i bought the rover before i put the lift on....
Old 12-09-2008 | 08:41 AM
discoxd's Avatar
same tires with a 2" rovertym lift and ome shocks...
Old 12-09-2008 | 12:06 PM
TD4141's Avatar
Cool. Thanks.
ljdiscovery
02-13-2016 11:21 PM
Emperor_MA
06-15-2011 11:21 AM
grandkodiak
03-04-2011 08:00 PM
Mr. Krisztian
08-16-2007 11:36 PM
bdharvey74
11-27-2006 12:17 PM
Quick Reply: Suspension, tires and lift question
