Swap seat bottoms side to side
Old Sep 22, 2020 | 04:57 PM
zuke's Avatar
Default Swap seat bottoms side to side
just wondered if anybody had tried this. The wear on the drivers side is always more and i noticed when I took some seats apart that this was possible...actually looked fairly easy. It would even out the wear.
Old Sep 22, 2020 | 05:03 PM
RoverPA's Avatar
Member
Consider dying them instead. I had the same issue and ended up getting leather dye and miscellaneous. The results were satisfactory.
Old Sep 22, 2020 | 06:11 PM
nashvegas's Avatar
Yes, you can swap them side to side. Not the entire seats, but the seat bottom cushion/leather.
Need to take both seats out of the car to do this.
Careful as you'll likely break the plastic "J-hooks" that hold the upholstery and cushion down and then need a visit to an upholstery shop (this is how the seats get "loose" which you see on tons of trucks for sale)
Old Sep 22, 2020 | 07:02 PM
Extinct's Avatar
It is a good idea. Can be done in the truck but much easier with the seats out and since it is only 4 bolts why not. To remove J hooks without breaking them try to roll them off, don't just pry or pull.
Old Sep 22, 2020 | 10:59 PM
snowmansgarage's Avatar
I picked up a passenger side seat bottom from a local Pick'nPull & installed on the driver's seat. No need to remove the seat from the vehicle, just be careful with the plastic trim covers that need to come off the seat as they are getting older. Super easy swap with no special tricks or tips needed, get familiar with the process on the junk yard unit and you'll be fine.
Old Sep 23, 2020 | 06:02 PM
Big Jim Swade's Avatar
I swapped my seat bottoms out back in 2017. I removed the seats to do it, wasn't bad at all.
Llamasayswhat
Aug 17, 2018 12:50 PM
TRIARII
Jan 19, 2017 09:26 AM
tnerb33
Nov 28, 2011 03:14 PM
Pacerlive
Oct 20, 2011 03:09 PM
jmccollister
Sep 10, 2008 08:29 AM
