What does it mean to "rebuild" a differential?
Old Sep 23, 2020 | 02:59 PM
Brandon318's Avatar
Default What does it mean to "rebuild" a differential?
I've had it cracked open while replacing one on my 2004. What does it mean though to rebuild one of these? What gets replaced or serviced?
Old Sep 23, 2020 | 03:11 PM
whowa004's Avatar
Generally they get rebuilt due to the ring and pinion gears failing. Also what gets replaced when re-gearing.
Old Sep 23, 2020 | 03:17 PM
acg's Avatar
acg
If you do quite a bit of offroading, look into changing from the 2-pin to 4-pin.... as well as pegging it:
https://www.ashcroft-transmissions.c...ff-centre.html
https://www.ashcroft-transmissions.c...gging-kit.html
Old Sep 23, 2020 | 03:40 PM
Brandon318's Avatar
The 2004 is dead quiet, but my 2002 has almost what sounds like a supercharger whine at highway speeds. Is this an instance where rebuilding the diff my be needed? I guess I should expand the question to what it looks like to rebuild the transfer case too...
Old Sep 23, 2020 | 04:19 PM
Richard Gallant's Avatar
@Brandon318 drain the transfer case and both diffs and refill them with good quality gear oil, a little heavier weight than stock. Your whine may well go away, I use a 75/140 Amsoil synthetic and my Disco has no whine
Old Sep 23, 2020 | 07:33 PM
ZGPhoto's Avatar
Just hit up Goldwing Rovers and get a used diff, they rarely fail unless you're doing trails.
Ducatiryan
Jun 21, 2017 09:09 AM
jwbelvi
Feb 10, 2016 10:42 PM
Pipedream
Oct 5, 2009 01:41 PM
Wade
Aug 25, 2009 06:25 PM
Torancis_LR
May 17, 2009 02:05 PM
