Sway Bar Disconnects.
Old Nov 25, 2009 | 01:04 PM
JHDisco2's Avatar
Default Sway Bar Disconnects.
Hi all,
I was given a set of disconnects for my Disco2 a while back. I was then told I could not use them because I have the ACE system.
My first question is.. Is this true?
If so... Will they work on a D1. I will give them to my buddy if so.
Thanks,
Jeff
Old Nov 25, 2009 | 03:03 PM
AK Rover's Avatar
No they won't work on a D1 because the sway bar design on a D2 is completely different. Yes you can use disconnects with ACE. Question is why do you need disconnects with ACE? From the factory ACE equipped trucks have more suspension travel than with standard sway bars.
Old Nov 25, 2009 | 04:08 PM
Tom,
You can't use quick disconnects on the ACE bars, the ECU will go cray and the sway bars will beat the under carriage to death unless you went into the ECU and shut the system down, along with pulling the fuse.
Old Nov 25, 2009 | 04:11 PM
AK Rover's Avatar
At least I was right about them not working on a D1.
Old Nov 25, 2009 | 04:16 PM
Yeh, those cold days haven't gotten to you altogether.
How is the world treating you?
Alex_M
Aug 26, 2021 09:03 PM
deer4011
Jan 12, 2021 07:10 AM
evansjoem
May 21, 2014 10:14 AM
fishEH
Oct 23, 2011 11:53 PM
kamileon
May 24, 2011 05:10 PM
