Sway bar disconnects
Old Nov 5, 2017 | 09:36 AM
Publix_Deli's Avatar
4wd High
Default Sway bar disconnects
I have a 2" suspension lift. I want to keep both sway bars on my D2 for highway driving and have disconnects for off roading. Replacing all four links with disconnects is kind of pricey, though. Couldn't I just put disconnects on the right side of the truck and a pair of standard front-length disconnects on the left side? It seems to me that's all it would take to remove most of the sway bars' limitation on suspension travel.
Old Nov 5, 2017 | 09:55 AM
alpinacsi's Avatar
Use the disconnect on the front and remove the rear completely. Unless you are using the vehicle for towing: you will most likely not notice the difference without the rear bar.
Old Nov 5, 2017 | 10:09 AM
Best4x4's Avatar
For a pure off road D2 sure removing em is fine. However a daily driver I highly suggest leaving the rear sway bay in place. Sure you won't notice it under normal driving conditions, but in the event you have to avoid something or steer sharply you'll be in for a surprise.
You can modify some Jeep TJ front disconnects to fit the front. I did it on one D2 I owned and they worked great. I used some JKS quick disconnects I had laying around from my Jeep days.
Old Nov 5, 2017 | 10:11 AM
4wd High
How did you have to modify the TJ disconnects?
Old Nov 5, 2017 | 10:55 AM
Alex_M's Avatar
Check out the link in my signature. I modified my factory links to have disconnects like three years ago. Cost was like $5 or something. I've had no issues out of them.
I second removing the rear sway. Completely useless, even at speed on the interstate.
Old Nov 5, 2017 | 11:08 AM
Best4x4's Avatar
All I had to do for the Jeep disconnects was drill out the D2 sway bar holes by just a size up. Or you could just use smaller bolts, but I just went with drilling out the holes.
Old Nov 7, 2017 | 12:33 PM
zoltan7's Avatar
I think I have the L8 disconnects. Cheap as you'd need them to be lol less than $100 shipped I think
As for the back, I run panhard conversion with no sway bar.
Things aren't too bad when driving considering how much lift I have. I will confirm this, if that panhard weld gives lol you can't steer it at all
So if you have a concern on your watt's busting or panhard weld snapping, then you should have some warrant for concern.
But to me, $100 gets it done
deer4011
Jan 12, 2021 07:10 AM
evansjoem
May 21, 2014 10:14 AM
fishEH
Oct 23, 2011 11:53 PM
kamileon
May 24, 2011 05:10 PM
JHDisco2
Nov 25, 2009 04:16 PM
