Swaybar disconnects or remove swaybars altogether?
My lift has been delayed due to springs being on back order from Rovertym, but should be here late next week. I put the brake lines on today (+6"
) and am prepping for the springs, shocks, dislocation cones, watts linkage, etc. to be delivered. Rovertym recommends either removing the swaybars or swaybar disconnects to gain the full suspension articulation the rest of the system makes the vehicle capable of. What are you all running, bars with disconnects or no bars at all? Pros/cons?
![Smile](https://landroverforums.com/forum/images/smilies/H5uKDcM.png)
on
It is a matter of choice and type of trails you go on.
Have you rebuilt your front drive line yet, if not could finish it off, so put that on your list to do ASAP. Also noticed you are running a K&N filter, do yourself a favor and get rid of it, it will trash your MAF and it lets way too much dirt thru and into the engine.
![Thumbs up](https://landroverforums.com/forum/images/icons/icon14.gif)
They still let in too much dust and dirt especially in an offroaded truck. That can cause very severe premature wear in your engine. A paper filter costs $20 and lasts a couple years.
They will be ome +3"sports, but I've already replaced the lines this weekend, the ABS extensions will be here this week with the rest of the kit (I hope).
Where's the best buy for disconnects, the ones I found were about $150. I was told by Rte the HD springs will negate a lot of roll, but that front bar is huge so I can see how removing it would cause it to drive sloppy. I will tow occasionally with it, but not enough to make the decision for me.
