Symptoms of a bad O2 Sensor
Old May 10, 2019 | 08:43 PM
Tristan Stumpf's Avatar
Default Symptoms of a bad O2 Sensor
If I have super low values from my upstream sensors, .006-.006, and downstream ones are still in the .400 range does that indicate a bad sensor?
Sorting out a high initial idle and rough running issue.
Thanks in advance
Old May 10, 2019 | 09:07 PM
redwhitekat's Avatar
What’s your codes ???
Old May 11, 2019 | 03:41 PM
Extinct's Avatar
They are either dead or super lean, but since your ds sensors are middle of the road my guess is dead. Check them with a elm327 and the torque app graph running on a cold start. cold start they shoudl immediately go to 1 volt for the first 10-20 seconds, then start falling till they start cycling. If they don't go to 1 volt on cold start - dead or wire is cut.
matt3502
Oct 26, 2016 06:27 PM
philwarner
Jun 17, 2015 10:27 AM
Joe Malouff
Jun 19, 2014 10:27 PM
cationmoted
Nov 30, 2010 06:10 AM
skipdow
Jan 21, 2006 05:10 PM
