T-case front output bearing.
Old Jul 1, 2013 | 07:44 PM
Mojigglins's Avatar
Default T-case front output bearing.
So today I noticed I have about .050" of play at the front output flange, wiggling 12 and 6 o'clock. ( used a dial gauge).
I have a few questions. Are the bearings lubricated by the t-case oil? I just developed a leak in my t-case and it was a bit low, I added about half a liter.
Next question, where can I get a bearing and seal kit for the output flange?
And last question, I have been looking at different options to add CDL and am now thinking if I need to replace the front output bearing I might as well go for the whole front housing CDL kit from toddco.
Anybody have any experience with this kit?
Also anybody out there installed the part-time 2wd fulltime 4wd adapter from toddco?
Seems to me that could save a fair amount of mpg not having to turn the front drive train all the time.
PS. I did my front prop shaft about a month ago, my leak showed up about three weeks ago along with a very slight vibrating felt in the seat between 30 and 45 mph. The leak is where the front output housing meets the main housing.
Thanks guys.
Old Jul 2, 2013 | 06:08 AM
First, if you have a leak then the flange probably got loose and then cut a cut on itself, If that is the case just buy a replacement flange.
What year id your Disco?
Also, don't waste your money on that 2 wheel conversion, there is no benefit to using it.
As for Toddco, find a better place to buy parts, their customer service is terrible and so are their prices. Depending on the style of shifter you want, you can buy a D1 shifter for around $150 or the cable type for around $200 and the CDL nose assembly for for under $200 used and guaranteed.
Old Jul 2, 2013 | 08:03 AM
Mojigglins's Avatar
I have an 02 SE.who would be a good supplier for the CDL noes assembly Would Paul Grant be able to supply CDL housing . I think 2wd adapter would be great! Unless going off road you wouldn't be turning almost 500lbs of drive train. Sound like mpg savings to me. I might fab up my own CDL leaver. I always liked the look of the older series land rovers with 3 gear shifters.
Old Jul 2, 2013 | 08:20 AM
I bet you will not find another person on this forum that has ever tried to convert to the 2 wheel adapter. The front diff will always be turning up to the t/case. There are a number of things that $319 might be well spent on.
Yes, call Paul, he should be able to supply the parts you need.
Have you seen the CDL conversion at the top of this section in Josh's write up?
Old Jul 2, 2013 | 08:32 AM
Mojigglins's Avatar
About putting a D1 t-case in a D2. Yes I have looked at it about 12 time. I want to fix my output flange issue sooner than later. So I think I will be contacting Paul today. I don't want it to get worse at least I caught it now an not when there is 1/16 of an inch of play.
Old Jul 2, 2013 | 04:23 PM
Mojigglins's Avatar
Turns out that it was the big nut that holds on the flange was loose,
anybody know what size and thread this nut is? I want to by a new one on my way home tonight?
Old Jul 3, 2013 | 09:24 AM
Might want to check the Rave for the torque settings, think it is around 350 foot pounds.
By the way, is it leaking oil, is so you will need to most likely replace the flane and seal.
Old Jul 3, 2013 | 10:08 AM
ZGPhoto's Avatar
119lb/ft
Old Jul 3, 2013 | 10:32 AM
Mojigglins's Avatar
@ Mike its not leaking at the flange. It leaks where the front housing meets the main housing, you can see where PO used some kind sealant instead of a proper gasket. I don't have time to fix right away.
kenk
Mar 22, 2017 10:16 PM
rfitterer
Jun 3, 2014 11:29 AM
wheelgarage
Feb 21, 2012 11:39 PM
EstorilM
Oct 11, 2011 08:13 PM
