t-case solenoid
Old Apr 30, 2009 | 10:50 PM
tango123's Avatar
Default t-case
I was having problem with my diff lock before until disco mike told me to power wash it underneath to clean it out a bit. It started working again. It goes low-to high no problem. The only problem that I'm having is that the diff lock light won't turn on when I shift it to the left side. Any advice would be greatly appreciated.
Old May 1, 2009 | 10:33 AM
That was to correct the linkage so you could shift into a locked position, this solenoid is a different issue not allowing you to shift out of low.
Old Jun 12, 2012 | 02:40 PM
SkymonkeyONE's Avatar
I have a 2000 Disco II with 155k miles and it will not shift into Low Range at all, hot or cold. The vehicle works perfectly otherwise. Is this solenoid the prime suspect? Sounds like it. Can anyone on here point me to a reputable Rover guy in the Phoenix or Tucson area? I'm from NC, but working in the Casa Grande and Coolidge, AZ area till the end of July. Thanks in advance!
Chuck Blue
Old Jun 12, 2012 | 05:44 PM
9 t0 1 odds it is the solenoid. Are you at least a little mechanical?? Save a lot of money if you pull the console and access the top of the t/case, remove the solenoid and be done with it or replace it.
Old Jun 12, 2012 | 05:56 PM
nychaze's Avatar
This will only prevent shifting into low range correct? or could you end up on a trail without being able to shift out of neutral? or i guess just as bad, not back into High?
Damn i wish i pulled this thing when i had everything apart a month ago. DUH!
Old Jun 12, 2012 | 09:41 PM
FLDiscoII's Avatar
If that solenoid goes you're stuck in whatever you were in last. Wouldn't be fun to have it fail on you.
Old Jun 13, 2012 | 10:06 PM
ekahi_1's Avatar
i just removed mine the other day kind a B#$%^ get to the little screws through the top but took me about 2hr total... Having LO 4wd is some much better now...
Old Jun 13, 2012 | 11:31 PM
Thanks for the info. I am 2000 miles from home, but carry plenty of tools to do this job as described. Thanks for the info.
Chuck
Old Nov 24, 2013 | 02:50 PM
rip5662's Avatar
I'm new here and have recently purchased a 95 Disco. Replaced engine, transmission. I put everything bk together and the truck doesn't pull itself. The transfer case worked before I changed the engine and tranny.
Old Nov 24, 2013 | 02:52 PM
rip5662's Avatar
I removed the solenoid at the top that DiscoMike suggested. I have the console out and the front prop shaft removed. I can see the front trying to turn but it will not move the truck. Any insight would be very greatful. It doesn't feel as though the transfer case is going into gear all the way.
