tachometer
Old Oct 30, 2008 | 09:19 PM
old gold's Avatar
Default tachometer
I have a 98 disco. The tachometer is not working. I checked the fuse panel and all looks well there.
I have checked over the Rave manual and can't locate any reference to where the sensing is done (maybe the engine computer?)
Any suggestions on how to troubleshoot?
Old Oct 31, 2008 | 08:55 AM
britishracinggreen's Avatar
Default RE: tachometer
Check the back of the alternator. There are to small wires (one is a spade terminal) that may be loose.
Old Oct 31, 2008 | 10:53 AM
If that is OK, then go have your alternator tested, it may be failing which is common.
Old Oct 31, 2008 | 03:54 PM
The tach gets its signal from the alternator, when the alt goes bad the tach will stop working.
Old Nov 1, 2008 | 05:12 PM
old gold's Avatar
I cleaned up the with the fast-on connection (white wire) to the alternator and all is well.
Thanks!
Old Nov 1, 2008 | 06:14 PM
Sweet! Love those free fixes, and thank you for reporting back with the repair.
Old Nov 2, 2008 | 08:21 AM
CandiMan's Avatar
The tach gets its signal fromthe alternator, that's different.Ilearn something new about these LR everyday.
Phototone
May 6, 2008 07:44 PM
Elliot214
Feb 13, 2008 11:28 AM
Claridget
Sep 6, 2007 08:46 AM
evoasis
Nov 2, 2006 03:57 AM
lbvbroker
Mar 4, 2006 01:28 PM
