Tackle Sunroof leaks and 3 amigos next
I have my engine running well enough for now to tackle the other bigish issues.
First of all the sunroofs were taped closed with a TON of very sticky tape. I have the tape off and I am removing all the goo with solvent end elbow grease but it looks like they are working. Fingers crossed. (I did not open them all the way because they are getting too much resistance from the goo.)
I assume that this is a run of the mill remove headliner, remove sunroof casette, fix drain issues, re-seal and replace. I have seen a few write ups about removing the headliner and some videos about the drains. Feel this is going to be alot of work but more patience than brainpower.
The 3 amigos are another issue. They are intermittent. If I can get them to behave with new speed sensors I will be happy. But if not do people ever simply remove the abs system and simply put in air lockers?
