Tackle Sunroof leaks and 3 amigos next
Old May 5, 2020 | 09:54 PM
ttownthomas's Avatar
Default Tackle Sunroof leaks and 3 amigos next
I have my engine running well enough for now to tackle the other bigish issues.
First of all the sunroofs were taped closed with a TON of very sticky tape. I have the tape off and I am removing all the goo with solvent end elbow grease but it looks like they are working. Fingers crossed. (I did not open them all the way because they are getting too much resistance from the goo.)
I assume that this is a run of the mill remove headliner, remove sunroof casette, fix drain issues, re-seal and replace. I have seen a few write ups about removing the headliner and some videos about the drains. Feel this is going to be alot of work but more patience than brainpower.
The 3 amigos are another issue. They are intermittent. If I can get them to behave with new speed sensors I will be happy. But if not do people ever simply remove the abs system and simply put in air lockers?
Old May 5, 2020 | 10:14 PM
Best4x4's Avatar
Look up Option B for the ABS issues
Old May 5, 2020 | 10:15 PM
I see those threads. thanks for the pointer.
Old May 5, 2020 | 10:29 PM
Best4x4's Avatar
Since your issue comes and goes it sure sounds like the wiring at the shuttle valve switches. Performing Option B should take care of that for good!
Columbiar
Nov 29, 2016 03:20 PM
jalodge
Oct 3, 2013 05:27 PM
mrb06lr3hse
Mar 11, 2011 01:36 PM
BajaXJ92
Nov 13, 2009 05:00 PM
wesk
Aug 30, 2007 02:37 PM
