Tail door lock actuator replacement
Old Aug 8, 2020 | 07:44 PM
greisinb's Avatar
Default Tail door lock actuator replacement
How big of a pain is it to replace the tail door lock actuator? I know in the passenger doors the recommended procedure is to remove the door frame (no thanks), is the tail door easier? Mine isn’t locking with the central locking and I have access to a cheap replacement actuator.
Old Aug 9, 2020 | 06:33 AM
zski128's Avatar
You need to remove the rear door panel which you can break the plastic studs so have extra of those. Otherwise it’s pretty straight forward. The passenger door actuators are not really that bad. Just have the windows rolled all the way up and remove all the window frame bolts. Have some one slowly raise the frame in the door high enough so you can remove the actuator. Removing the wire links is attached to the actuator is the pain in my opinion.
Old Aug 9, 2020 | 10:57 AM
04disco2va's Avatar
I just did this a month ago. Not difficult. Zski128 is correct you will definitely break some plastic fasteners as you remove the inner panel. Have extra on hand. Good luck.
Old Aug 9, 2020 | 11:16 AM
greisinb's Avatar
Are the plastic fasteners for the tail door the same fasteners as for the passenger door cards? I have lots of those on hand.
Old Aug 9, 2020 | 01:04 PM
zski128's Avatar
No they are different. They slot into the fiber board backer. Best to used a trim removal tool if you have one and go slow.
Old Aug 9, 2020 | 02:29 PM
greisinb's Avatar
Thanks for the heads up and the photo!
Externet
Jan 17, 2013 05:12 PM
NiteTrain
Oct 4, 2012 06:41 PM
gavone1976
Mar 10, 2011 01:08 PM
Gerard
Mar 1, 2011 10:37 AM
llPANCHOll
Aug 21, 2009 09:18 PM
