Buying used door actuator
Old Feb 28, 2011 | 07:05 PM
Gerard's Avatar
Default Buying used door actuator
Hello,
My two rear doors and driver front door power locks have failed and diagnosing it seems to be the actuator.
If I purhcase a used actuator will i be able to program the used actuator to match my current key thereby avoiding to have to replace my working front passenger door and rear trunk door actuators.
Pls. advice....if there is another better option pls. help...I am trying to avoid having to get new actuators from the dealer which is in the range of 250$ and up a piece. Crazy.
Thanks,
Gerard
Chicago
Old Feb 28, 2011 | 10:41 PM
thospb's Avatar
The Door Lock Actuators are hard-wired, slave devices that recieve a command from the Remote Lock Module. There is no programing required. The Door Lock Cylinder is seperate from the Actuator so your current key will still work.
I got my Actuator from here, they get $120 -130,
http://www.partsgeek.com/catalog/200..._actuator.html
Old Mar 1, 2011 | 10:37 AM
Gerard's Avatar
Thanks for your reply.
Gerard
Brad S1
Jan 23, 2018 09:02 AM
kristofferzen
Sep 10, 2015 02:11 PM
