Tail light question
Old Feb 16, 2016 | 04:54 PM
Tracker1996's Avatar
Default Tail light question
Will '03/'04 tail lights fit 2000 year model? I.e. Plugs and fitting in hole right
Old Feb 16, 2016 | 05:11 PM
Alex_M's Avatar
They may fit, but they won't work right because your reverse lights are in your tail lights and your signals are in your bumper. The 03-04 is the opposite with reverse lights in the bumper and the signals are in the tail lights.
Old Feb 17, 2016 | 07:18 AM
dgi 07's Avatar
They fit. but as Alex said, the wiring is different.
You can take a couple hours and run extensions to the wiring and make it work. Solder and shrink wrap, no butt connectors. Too much moisture to cause corrosion. Couple hours max. But it can be done.
Old Apr 24, 2021 | 06:43 AM
Christy Williams's Avatar
5th Gear
Default Will 2000 fit the 2004 and work?
I have 04’ Disco 2 and my lens are cracked. Since my bumper lights work fine will they function the same up top? Will it appear that my reverse lights are on if I just plug and play? I do not have the luxury of running new wires.
shady milkman
Apr 13, 2020 05:55 PM
wcr4x4
Dec 8, 2013 04:45 PM
mattrickman
Sep 17, 2009 01:36 AM
Aj6543
Sep 4, 2009 10:37 AM
pilsner
Dec 14, 2008 08:20 AM
