Tail light swap/upgrade
Old May 16, 2019 | 03:26 PM
KC_Rover's Avatar
Default Tail light swap/upgrade
Gents,
I have a 2001 D2 needing a new drivers side rear upper tail light due to a crack in the housing and now the marker lights front and rear as well as the license plate light do not work. Keeps blowing fuses.
I have in my possession a pair of 03-04 rear upper tail lights
I have searched this forum as well as others for anyone who has done this and haven't gotten a lot of traction.
I know these are not plug and play but thanks to Zuke, I have the pigtails and know how to solder. I'd also add the reverse lights to my roof rack for simplicity.
However, I was wondering if anyone has taken this step before me that could shed some light on the swap I'm considering.
If this winds up being too big of a deal, I'll gladly swap someone for the 99-02 tail lights.
Thanks!
Old May 16, 2019 | 06:24 PM
shanechevelle's Avatar
Yea, put originals back in.
There are rovers in the yards around you, you just have to find them.
Old May 16, 2019 | 08:15 PM
Best4x4's Avatar
99-02 have better rear lens IMHO vs 03-04 which are delicate and crack easy.
Old May 16, 2019 | 09:50 PM
mollusc's Avatar
i have a spare set of lights on my '99 if you're interested in them.
Old May 17, 2019 | 09:59 AM
Alex_M's Avatar
If you know how to wire stuff you'll have no problem. Run the reverse light circuit down to your bumper (that's where they are on the 03-04), and run the turn signal up from the bumper to the tail light. They just flip flopped them between old and facelifted. Be sure to use heat shrink; you're going to get a lot of moisture there.
Edit: while you're at it, throw some LEDs in your reverse lamps. Especially having the tinted lamps that your truck has, that will help you out a lot.
Surmize
Sep 15, 2019 06:36 AM
Jeff Blake
May 30, 2018 12:42 PM
EricTyrrell
Aug 16, 2013 07:19 AM
bowtiecb
Jun 6, 2008 07:05 AM
fluffdaddy
Mar 29, 2008 06:24 PM
