Tape and some adhesive removed to discover working sunroofs
Old May 6, 2020 | 07:54 PM
ttownthomas's Avatar
Default Tape and some adhesive removed to discover working sunroofs
I have unglued and untaped enough of both sunroofs that I am glad to say that they open! I assume they were taped up because they leak (there were still drips even with the tape). I assume, worst case, that I need to take the headliner down and remove the sunroofs to re-seal them and fix the drains. If so will they come out completely including those black trim rings? I would much rather finish cleaning the goo on the bench vs leaning over the roof on a latter.
Old May 6, 2020 | 08:24 PM
Red5's Avatar
Yeah, if you remove all of the little torx screws, the bottom tray will come down and the plastic trim will come off the top. Then you can clean and reseal. The plastic trim is sealed to the roof with a thin foam strip, I removed all of that and reassembled with a bead of RTV. No leaks for 5 yrs now.
Old May 6, 2020 | 10:45 PM
this is after dropping the headliner?
Old May 7, 2020 | 07:13 AM
Sixpack577's Avatar
Yes, you need to remove the headliner.
Old May 7, 2020 | 07:31 AM
Red5's Avatar
Sorry, yes. Headliner has to come out first.
Old May 8, 2020 | 09:50 AM
Jason_B's Avatar
You are talking about the thin metal tray on the inside of the vehicle right? Do you think black RTV is good for this sealing? Thanks!
Old May 8, 2020 | 12:29 PM
Red5's Avatar
Yes, the metal tray that holds the motor and slides. But you only seal the plastic cups in the corners, not the whole tray to the bottom of the roof. The long bead of sealant goes on the bottom side of the plastic trim before you reinstall it on the top of the roof. I used silicone for the corner cups and blue for the roof trim, but black would work fine too.
hilltoppersx
Oct 6, 2022 05:10 PM
JoJo The Giraffe
Feb 28, 2018 02:44 PM
94svt50
Nov 3, 2013 04:27 PM
hhalimi
Mar 9, 2012 02:05 AM
noahsfortune
Feb 5, 2010 08:21 PM
