Tapping the suspension compressor ?
Old May 6, 2024 | 10:35 AM
Externet's Avatar
Question Tapping the suspension compressor ?
Hi.
Has anyone tapped the suspension compressor to supply air pressure to fill tires or something ? I believe can supply almost 100 psi easily. Saw a pneumatic jack that may be very happy with it.
Old May 6, 2024 | 11:32 AM
mollusc's Avatar
This has been asked over and over again.
It has a very small displacement and will probably burn out before you get much done.
Old May 7, 2024 | 02:14 AM
rikkd's Avatar
I've thought about it too. I know someone on the forum (I think Discorama but please correct me if I'm wrong) put a harbor freight air compressor in its spot and did a write up on it? Genius idea so I copied the design and did it myself but found it hard to inflate 4x 32" tires on a 16inch rim. I ended up replacing the air compressor with a Smittybilt and it worked well!
shmoo235
Apr 21, 2024 08:45 PM
Laurensvh
Sep 13, 2023 01:47 AM
viewsonic
Nov 16, 2022 04:58 PM
Tnlr4
LR4
Aug 21, 2021 06:50 PM
wsroufe
Feb 8, 2011 09:48 PM
