TC leak from sensor
Old May 20, 2019 | 05:44 PM
Ben Matheson's Avatar
Default TC leak from sensor
After having my TC resealed it's started leaking again. Appears to be the sensor on the front above the drive shaft. I assume there is an o ring that seals it? Is the sensor screw in or pressed in?
Worth just trying to tighten it first?
Old May 20, 2019 | 06:35 PM
Extinct's Avatar
Send a pic of which one - I have two on the floor I can check for you.
Old May 20, 2019 | 06:51 PM
That's the front shaft on the far right of the picture
Old May 20, 2019 | 06:52 PM
Old May 20, 2019 | 07:11 PM
My best guess is it's number 3 on this page. So either washer not sealing or can it leak through the actual switch itself. Does the fluid level sit that high with the vehicle stationary? Need to know if it will gush gear oil if I remove it lol
Old May 21, 2019 | 05:56 PM
Extinct's Avatar
Ok, so no way should you be leaking from that switch, it is way above the fill plug. Have you pulled the plug to check the oil level yet? Do you park facing downhill? Anyway, pulled mine out, there was no seal washer but I would recommend one - copper or plastic. I see in the rave section they talk about he sealing washer.
Old May 21, 2019 | 06:03 PM
I assume the oil sloshes up there while driving and what I see on the driveway is residual. Sounds like it screws in so I'll see if it's loose.
journeyman
Nov 20, 2023 04:13 PM
bantham1
Sep 20, 2015 08:04 AM
HighOnRover
Mar 7, 2014 05:13 PM
wheelgarage
Jan 18, 2012 01:50 AM
thehun
Oct 5, 2011 11:21 PM
