TC leak from sensor
Old 05-20-2019, 05:44 PM
Ben Matheson's Avatar
Default TC leak from sensor
After having my TC resealed it's started leaking again. Appears to be the sensor on the front above the drive shaft. I assume there is an o ring that seals it? Is the sensor screw in or pressed in?
Worth just trying to tighten it first?
Old 05-20-2019, 06:35 PM
Extinct's Avatar
Received 1,422 Likes on 1,013 Posts
Send a pic of which one - I have two on the floor I can check for you.
Old 05-20-2019, 06:51 PM
That's the front shaft on the far right of the picture
Old 05-20-2019, 06:52 PM
Old 05-20-2019, 07:11 PM
My best guess is it's number 3 on this page. So either washer not sealing or can it leak through the actual switch itself. Does the fluid level sit that high with the vehicle stationary? Need to know if it will gush gear oil if I remove it lol
Old 05-21-2019, 05:56 PM
Extinct's Avatar
Ok, so no way should you be leaking from that switch, it is way above the fill plug. Have you pulled the plug to check the oil level yet? Do you park facing downhill? Anyway, pulled mine out, there was no seal washer but I would recommend one - copper or plastic. I see in the rave section they talk about he sealing washer.
Old 05-21-2019, 06:03 PM
I assume the oil sloshes up there while driving and what I see on the driveway is residual. Sounds like it screws in so I'll see if it's loose.
journeyman
11-20-2023 04:13 PM
bantham1
09-20-2015 08:04 AM
HighOnRover
03-07-2014 05:13 PM
wheelgarage
01-18-2012 01:50 AM
thehun
10-05-2011 11:21 PM
Quick Reply: TC leak from sensor
