Td5 service kit
Old Feb 10, 2023 | 09:55 PM
Mi..!'s Avatar
5th Gear
Default Td5 service kit
Hi
Just wondering if anyone can help me with part numbers for a 2000 middle Discovery Td5
The diesel filter that is situated above the right tyre had been changed to the type that doesn't drain via the switch and is actually manually drained
I need part numbers for the following
Diesel filter
Oil filter
Just minor service
Thanks in advance
Old Feb 10, 2023 | 10:55 PM
Dervish's Avatar
Fuel filter -> ESR4686
Oil filters -> ERR6299 and LPX100590
When changing the roto filter that sits on upwards under a cover, make sure You do NOT over tighten the bolts as they easily shear the threads of the aluminium stand. And remember to oil the oil filter gasket (rubber thingy on the filter) before installing and do NOT tighten it as hard as you can. Hand tigh is enough. Same with the fuel filter, lube the gasket a bit.
Old Feb 11, 2023 | 03:11 AM
Mi..!'s Avatar
5th Gear
Default Thanks so much Bud ... really appreciate the advice
thanks
titpygmy
Defender
Jun 30, 2021 07:33 AM
treant985
Nov 23, 2016 11:12 AM
TRIARII
Nov 25, 2012 08:57 PM
disco andy
May 11, 2010 12:44 PM
Mountainman
Defender
Feb 14, 2008 12:12 PM
