Td5 service kit
Hi
Just wondering if anyone can help me with part numbers for a 2000 middle Discovery Td5
The diesel filter that is situated above the right tyre had been changed to the type that doesn't drain via the switch and is actually manually drained
I need part numbers for the following
Diesel filter
Oil filter
Just minor service
Thanks in advance
Diesel filter
Oil filter
Just minor service
Thanks in advance
Fuel filter -> ESR4686
Oil filters -> ERR6299 and LPX100590
When changing the roto filter that sits on upwards under a cover, make sure You do NOT over tighten the bolts as they easily shear the threads of the aluminium stand. And remember to oil the oil filter gasket (rubber thingy on the filter) before installing and do NOT tighten it as hard as you can. Hand tigh is enough. Same with the fuel filter, lube the gasket a bit.
treant985
Nov 23, 2016 11:12 AM
