TD5 Thermostat for V8
Old Jan 14, 2016 | 12:04 PM
DiscoCam's Avatar
Default TD5 Thermostat for V8
I have heard a lot of good things about the lower temp TD5 thermostat. I just don't know which one to get. On AB, there is a soft spring tstat which I assume is the TD5 spec ($50). Lucky 8 has one for $80 (I think it's genuine LR). Which one should I get? Is there a cheaper one out there?
Thanks.
Old Jan 14, 2016 | 12:13 PM
drowssap's Avatar
get the genuine there have been a lot of problems with the aftermarket t-stats
Old Jan 14, 2016 | 12:35 PM
coors's Avatar
I agree with drow. Get the OE LR stat.
Old Jan 14, 2016 | 12:52 PM
DiscoCam's Avatar
Thanks for the fast responses. I will get the genuine LR TD5 thermostat.
Old Jan 14, 2016 | 01:37 PM
DiscoCam's Avatar
Now that I think about it, the top hose assembly could use replacing. Genuine on this too or is aftermarket ok?
Old Jan 14, 2016 | 02:56 PM
Alex_M's Avatar
If you need to replace hoses too then just go for an inline stat. Hoses are fine aftermarket.
Old Jan 14, 2016 | 06:15 PM
DiscoCam's Avatar
good point on the inline stat. Thanks.
pgaukroger
Feb 29, 2016 05:56 AM
Dave2345805
Off Topic
Aug 2, 2015 09:09 PM
trini defender
Defender
Dec 11, 2006 05:14 AM
plutonic2
Jan 27, 2005 08:58 AM
Brian
Oct 24, 2004 11:59 AM
