TD5 turbo diesel help
Old Jun 5, 2021 | 05:29 AM
Nght's Avatar
Default TD5 turbo diesel help
It was starting up perfectly fine for about 3 months now all the sudden with not a lot of driving but enough just going up the down the street once or twice a day probably about a 5 minute drive if that there is white smoke when I tried turn it over and if I hold my foot on the accelerator for about 20 seconds starts up and runs fine but over recently the last 2 days it's been cutting out after driving 5 mins which makes me think it's a fuel problem but then I sprayed the mass air flow sensor with the cleaner and it started up straight away no problems but 10 minutes down the street it cut out and lost all power so I don't know if it's the MAF or if it's a few thing anybody has some inside ID like to know and I have checked there's no oil in the radiator so it's not a head gasket leak or not oil but white stuff from the oil
And there's no fault codes on the ECU
Old Jun 5, 2021 | 01:32 PM
Richard Gallant's Avatar
@Nght Try the defender section it is same engine, most of the Disco's owners here are V8 gas
Old Jun 5, 2021 | 07:01 PM
The Deputy's Avatar
I'd start with fuel presure reading, or changing fuel filter. Since you have no codes, fueling would be my first "go-to".
Pappion
Dec 1, 2016 03:38 PM
Cheryl Richards
Mar 11, 2013 08:04 PM
Hopeddd
Jan 23, 2012 09:57 PM
DiscoRom
Nov 9, 2009 07:16 AM
defcruiser
Defender
Mar 26, 2007 07:00 AM
