temp gauge and glow plug problems
Old Mar 7, 2015 | 09:46 AM
discomerc's Avatar
6th Gear
Default temp gauge and glow plug problems
hi i have just finished putting a 260hp merc om605 in my disco 2 removing the td5.the ecu is still fitted and most things work but the temp gauge dose not.when you turn on the ignition the gauge goes up then down and the overheat red light comes on, i also think this is why there is no power to the glow plugs as it thinks the engine is hot. i have the td5 temp sensor wired in . any help with this would be good
Old Mar 7, 2015 | 05:06 PM
OffroadFrance's Avatar
Congratulations on achieving the project. It sounds like an earth problem or an ECU incompatability as far as the temp gauge as you are using the TD5 sender/sensor with the D2 dash gauge. Re the glow plugs, both are 5 cylinder engines and I assume the same voltage glow plugs. Are you using the TD5 ECU for the glow plugs or the Merc ECU. It does sound like the issues are both linked as maybe the temp is saying to the ECU that it's hot enough and therefore no power is demanded or needed to the glow plugs. Have you bench tested the temp sender and also shorted the pins on it to see whether rises to hot on the gauge?
Old Mar 8, 2015 | 10:52 AM
discomerc's Avatar
6th Gear
thanks ill put a pic up if i can.using td5 for glow plugs haven't had time to do some more testing,the ecu is td5 maybe an earth prob. was trying to get other peoples ideas on what to do as abit stumped
Old Mar 8, 2015 | 11:03 AM
discomerc's Avatar
6th Gear
temp gauge and glow plug problems-dsc_0200.jpg for offroadfrance
Old Mar 8, 2015 | 07:25 PM
Attachment 24876 for offroadfrance
That looks the business discomerc, fantastic very professional job. Thanks for the photo well worth the study of it, I enlarged it for more detail. The front shock towers look like D1 fitments am I correct?
Old Mar 9, 2015 | 01:19 PM
discomerc's Avatar
6th Gear
thanks again offroadfrance they are d1, using parts from my old disco
OffroadFrance
Off Topic
Jan 14, 2015 04:56 PM
cookie110
Apr 30, 2013 12:19 PM
collin Barrows
Aug 8, 2011 09:33 PM
shartzer
Oct 29, 2010 12:27 PM
iownme
Nov 10, 2009 06:17 PM
