temp gauge problem
Old Nov 12, 2006 | 11:25 PM
rhymered's Avatar
7th Gear
Default temp gauge problem
since i have owned my 98 disco the temp gauge has only worked one time, where is the temp sensor located, is it a one wire or two wire sending unit? is this normal on these things to give problems and would this affect a fast idleing issue? i would like to know what the temp is since it just overheated last night.
Old Jan 13, 2007 | 01:00 AM
julesincali's Avatar
8th Gear
Default RE: temp gauge problem
Did you check the coolant levels?
Old Jan 13, 2007 | 09:47 AM
Sounds like your temp sensor is either failing or has a ground problem. As fot the fast idle problem, most likelky your stepper motor is dirty, probably cleaning it will help.
Mike
Rover_Hokie
Feb 2, 2014 03:52 PM
axelbeteta
Dec 15, 2012 09:32 PM
collin Barrows
Aug 8, 2011 09:33 PM
rightsandlefts
May 7, 2009 10:25 PM
ozmoto
Sep 10, 2005 01:07 AM
