Temp Guage
RE: Temp Guage
ORIGINAL: vinvelasco
nope i didnt bleed it. I didnt know i should have i replaced it coz it was leakin at one end of the tie cable. Should have asked here first. So, i need to replace all the coolant hoses. How many are there in all? If its a bubble, how do i fix it? Is it an easy thing 2 do or should i get a mechanic 2 do it? I hope i didnt mess up the sensor
Yeah I wouldn't worry about messing up the sensor too much, they're pretty cheap compared to "messing up" the engine if you get a hot spot somewhere. I'd replace the other hoses before you bleed it else you'll be doing it twice. Unless you need to drive the truck.
Yes just plug the connector back on the temp sender. It shouldn't be too far away from the sender if you just knocked it off.
