Temp Guage
Old Aug 13, 2008 | 07:48 PM
Default RE: Temp Guage
CandiMan-Good call.
Old Aug 17, 2008 | 12:16 AM
vinvelasco's Avatar
thanks for the info guys. i tried to look up the repair manual for my truck but i kinda lost my rave cd. where exactly can i find the harness for the sending unit? do i just plug it in again?
Old Aug 17, 2008 | 06:22 AM
mordor110's Avatar
ORIGINAL: vinvelasco
nope i didnt bleed it. I didnt know i should have i replaced it coz it was leakin at one end of the tie cable. Should have asked here first. So, i need to replace all the coolant hoses. How many are there in all? If its a bubble, how do i fix it? Is it an easy thing 2 do or should i get a mechanic 2 do it? I hope i didnt mess up the sensor
Yeah I wouldn't worry about messing up the sensor too much, they're pretty cheap compared to "messing up" the engine if you get a hot spot somewhere. I'd replace the other hoses before you bleed it else you'll be doing it twice. Unless you need to drive the truck.
Yes just plug the connector back on the temp sender. It shouldn't be too far away from the sender if you just knocked it off.
Old Aug 17, 2008 | 07:47 AM
It will be on the top of the engine somewhere. Usually towards the front of the engine.
2Discos
Sep 9, 2013 04:23 PM
b c
Jan 19, 2012 08:49 PM
dgm
Jul 20, 2011 05:20 AM
duclover
May 23, 2010 04:44 PM
rykrover
Mar 1, 2010 06:24 PM
