Temp Spike
Old Jun 1, 2010 | 04:53 PM
tigertrakstar1's Avatar
Default Temp Spike
Hey guys,
I have a 96 disco with about 150,000 miles on it. Today I noticed when I sitting at a redlight for a prolonged amount of time with the a/c on that the temp level spiked some. When I driving it fell back to the normal level. Is this anything that is indicative of something else?
Old Jun 1, 2010 | 05:13 PM
discomedic4's Avatar
Did you check your coolant level? Might not have anything to do with it but worth checking real quick.
Old Jun 1, 2010 | 06:16 PM
Bad a/c fans.
Go turn to ignition to the "ON" position and make sure the a/c is on, do you hear the fans in front of the radiator?
Old Jun 1, 2010 | 10:07 PM
cranky's Avatar
Could also be your fan clutch. In warm weather you should notice the sound change from under the hood as the fan works harder. After you take off from stand still you should notice the sound reduce to a more normal engine noise.
________
Marijuana card
grandkodiak
Sep 30, 2013 06:01 PM
sloppyjoe
Mar 13, 2009 05:46 PM
Spike555
Mar 9, 2009 07:27 AM
NiteTrain
Dec 3, 2008 09:03 PM
whurst79
Jun 12, 2008 04:26 PM
