Anti-lock light
Old May 20, 2010 | 08:28 PM
jbriggs's Avatar
Talking Anti-lock light
My anti-lock light came on the other day after some numb-skull turned in front of me and I had to lock it up. I couldn't remember if this was normal or not and the brakes were still working fine so I pressed on with my errand. I had it turned off while I picked up the kids and it went out after starting again and rolling over 5-7MPH. Later when I went to work it came on again while I was braking lightly coming up to a stop sign. Cycled it and it went out. Last night I was going to work and the pedal would shudder like it's supposed to when anti-lock is doing it's thing and the light came on again, but I was on dry pavement. Pulled the ABS fuse to drive it home so I would have brakes. Now I'm pissed because about 3 weeks ago I replaced brake discs and pads all the way around, cleaned everything real good and did a thorough inspection and didn't find anything wrong. The only other thing I have worked on is trying to figure out why my cruise doesn't work. So I wracking my brain trying to figure out what to do next because it's one of the most exspensive systems on the planet to repair and I'm watching my spending like everyone else in the world today. Then it hits me, I did a vacum test on the hoses and diaphram the other day. I check and sure enough I left one of the hoses off that goes to the brake/cruise system. Morale of the story: "Last thing f***** with is the first thing thats bad"!! Reference: (jbriggs USAF circa 1985)
Old May 20, 2010 | 09:43 PM
greg409's Avatar
Your ABS sensors may need to be reset, (they might be pushed back due to loose hubs)
Follow the sensor line to the hubs, the rubber bushing that the line passes thru' needs to be pushed in as far as it will go (I don't think it will bottom out, tho').
I use an adjustable wrench opened to clear the wire.
I tapped it in with a rubber mallet
This bottoms the sensor, driving will automatically clearance it.
That's all it was in my case, very common
It's in the rave manual, below in my sig.
luck,greg
Old Jun 1, 2010 | 12:56 AM
jbriggs's Avatar
luck,greg
I tried it and it didn't work. Did you loosen the two bolts that hold the sensors in place first? It looks like a plate that holds the sensor there.
Old Jun 1, 2010 | 08:30 AM
Open hood.
On the passenger fender is a fuse box.
Open the fuse box.
Find the 30 amp ABS pump fuse.
Remove fuse.
Close fuse box.
Close hood.
ABS light stays on.
You no longer have ABS but the brakes will work just fine.
Your cruise not working has nothing to do with the ABS.
Old Jun 1, 2010 | 09:32 AM
kenk's Avatar
There are no bolts holding the sensor in. Them 2-17mm bolts are the upper swivel pin. The sensor is a press fit that can be removed independently.
By the way the ABS was cycling on dry pavement, sounds like a pump/modulator fault.
Old Jun 2, 2010 | 12:22 AM
jbriggs's Avatar
Yeah thats what I think too. It happened right after I did the front brakes so I thought that might be it. I'm going to try to bleed the brakes again because if the pump/modulator/valve is full of air it might di it also. I had my 7 year old pumping and holding the brakes and he did a great job but I'm not sure if he was strong enough to get it down all the way. I pulled the fuse as soon as it happened and have brakes now but no anti-lock. I'm getting ready to trade this in or sell and get a new vehicle so I need to fix the anti-lock problem.
thearmlesswonder
Dec 10, 2014 10:27 AM
targotsi
Sep 25, 2008 08:29 PM
redhotbuzz
Aug 25, 2008 08:32 PM
briauna2003
Aug 15, 2008 08:37 AM
sfxgamer
Jun 19, 2007 02:29 PM
