Temperature spike in negative degree weather
Old Jan 13, 2015 | 11:32 AM
DiscoShiznit's Avatar
3rd Gear
Default Temperature spike in negative degree weather
Hi all, recently after i let my car warm up it gets a temperature spike up to the red zone after about a minute of driving then returns back down to the middle as normal. I live in Grand Forks, ND the coldest city in the US. Most days it doesn't even get above 0. Is it possible that it is over heating or do i just have a faulty thermostat? Any help is greatly appreciated. Thanks - Aaron
Old Jan 13, 2015 | 12:48 PM
bmeier's Avatar
Definitely buy an ultra gauge, If you replace your t stat , look into the Grey ones vs the tan, made my rig 12 degress cooler. I blew my headgaskets by not having an aftermarket temp gauge, went into the red for a sec and done sauce......
Old Jan 13, 2015 | 01:20 PM
cappedup's Avatar
Be careful. You are in danger of frying your car.
Remember the in dash temp gauge is pretty much an on/off display.
Is the coolant mix correct?
Something could very much have been stuck.
It could be over heating 'and' you have a faulty thermostat. Instead of 'or'.
As mentioned one over heating incident can lunch things. Get a real time temp gauge. So at least you can shut it off if it does climb.
Read around here for what are acceptable temps. Mine are between 194-199, on most days, journeys, regardless of outside temp.
Good luck.
Old Jan 13, 2015 | 08:55 PM
driftology's Avatar
Make sure your fan clutch is in good shape.
Lord Wert
Aug 30, 2013 04:42 AM
JohnKimble
Jan 16, 2013 06:26 PM
kkg10
Freelander
Jan 3, 2010 02:55 PM
FTB 2000 Disco
Dec 4, 2006 12:03 AM
Brad S1
Jul 5, 2006 05:54 PM
