Temps ??
Old Apr 18, 2018 | 04:30 PM
redwhitekat's Avatar
Default Temps ??
at what temperature does your disco run at coooant temp ???
Old Apr 18, 2018 | 04:54 PM
samroy92's Avatar
I have the low temp t-stat installed, so about 185-188deg F at highway speeds. And about 190-198deg F in the city. Also recently replaced the radiator + hoses.
Old Apr 18, 2018 | 05:22 PM
Alex_M's Avatar
I've upgraded my entire cooling system (if you're curious, cooling system upgrade is under the link in the signature), but min sits exactly where I like it. Stays between 185-195. Cruises around 187-190.
Old Apr 18, 2018 | 06:15 PM
Just picked my my 2003 disco I just bought they thermostat was replaced last year however it's oem and my temps are 212-220
i will be getting the 180 from Atlantic British
as I don't think I can buy a 180 here in Canada
Old Apr 18, 2018 | 06:37 PM
LR03NJ's Avatar
Heres my temp at 50 degrees ambient temp. Getting codes 0126. Replaced tstat to grey. Now back to normal.
Old Apr 18, 2018 | 06:58 PM
Grey is the warm weather Tstat ??
Old Apr 18, 2018 | 06:59 PM
180 f ??
Old Apr 18, 2018 | 07:13 PM
LR03NJ's Avatar
Its genuine 180 grey tstat i think its for defenders or RR.
Old Apr 18, 2018 | 08:27 PM
abran's Avatar
Its for the diesel D2s. If you call an LR dealer in the US and ask for that part number it will not show in their system.
Old Apr 18, 2018 | 08:41 PM
Jeff Blake's Avatar
Atlantic British only sells the Motorad 180 I believe. It's creme colored. Don't get that.
