Terrafirm Medium Springs - Unloaded Truck
I have the same set up, stock 2001 SE, TF 2" Medium +2" shocks, looks, and works beautifully, except for a CLUNK Im having trouble diagnosing in the rear! drives me nuts. Everything is tight underneath, not sure if it's my rear door? Spare tire mount? The sound needs to get more progressed I guess before I can find it...
![Confused](https://landroverforums.com/forum/images/smilies/muBAORM.png)
I have the same set up, stock 2001 SE, TF 2" Medium +2" shocks, looks, and works beautifully, except for a CLUNK Im having trouble diagnosing in the rear! drives me nuts. Everything is tight underneath, not sure if it's my rear door? Spare tire mount? The sound needs to get more progressed I guess before I can find it...![Confused](https://landroverforums.com/forum/images/smilies/muBAORM.png)
Check the watts linkage and arms. I had a bad clunk and thought I needed new watts bushings (which are not cheap) but it turned out I had not tightened the outer bolt all the way on the drivers side arm. Once I tightened it up all has been good.
This picture shows the outer bushings I had to tighten and arms in green. Check all 5 bushings for wear though. You should not be able to move the 2 green arms in the picture by hand. If you can then you either need to tighten them up or replace the bushings.
