Terrafirma 2" med vs. HD lift
Old Feb 10, 2017 | 11:56 AM
brolome's Avatar
Would a 3" lift require any additional parts like extended brake lines, axle regearing or steering components?
Old Feb 10, 2017 | 12:14 PM
Alex J's Avatar
To be safe you would probably want to change the watts link at the back so it doesn't rub on the bracket, adjustable panhard rod in the front, longer brake hoses and ABS sensor wires and drive shaft flange spacers. Axle gearing is determined by tire size and not lift height.
Old Feb 10, 2017 | 05:37 PM
Discoaddictnorth's Avatar
Funny
When I mentioned similar complications of a 3 inch lift on another thread I got quickly shot down and told it is "well documented" that ther is no issue with 3 inch lift.
I also mentioned driveline angle as a concern (rear shaft u joint conversion and definitely a front shaft upgrade.
I also think that 3 inch is overkill for a truck that is not going to see "real" offroad use
disco202
Mar 22, 2021 10:06 AM
jycsalas
May 23, 2019 03:02 PM
hayleyspop
Jan 10, 2014 08:50 AM
wheelgarage
Jul 23, 2012 10:10 PM
Erwan88
Feb 20, 2012 05:15 PM
