TerraFirma lift question
That being said have a good look/listen at the other suspension links/bushings especially in the rear. If they are worn the add articulation from the lift could be causing them to make noise. Check the Watts linkage, and if you still have an anti-sway bar start with the link ends. I've been there done that. Good Luck!
If you can, or know someone who can do some lite fab work you can lower the front shock turrets like Alex_M did here > https://landroverforums.com/forum/di...rs-free-78143/
You can also make rear upper mounts that are lower than stock too.
As for adding more weight than just steel bumpers... A winch Will add more weight, too, at least to the front.
OverRover (12-01-2017)
http://www.rte-fab.com/products?page...category_id=52
wheelgarage
05-10-2012 11:39 PM
