TerraFirma lift question
Old Nov 30, 2017 | 05:05 PM
Are you sure you have the TF134 shocks?
Old Nov 30, 2017 | 05:07 PM
satxpipe's Avatar
Yep, tag is still on both of them.
Old Nov 30, 2017 | 05:30 PM
OverRover's Avatar
Originally Posted by satxpipe
I believe the TF134's are the 3+ length which is the longest TF makes. The fronts have no tags or markings that I can see so I'm assuming they are extended as well, as the back has more clunking noises than the front.
With the TF134 in the rear, unless someone put a spring spacer or extra spring isolator, those shocks should be more than fine with a 3" lift kit.
That being said have a good look/listen at the other suspension links/bushings especially in the rear. If they are worn the add articulation from the lift could be causing them to make noise. Check the Watts linkage, and if you still have an anti-sway bar start with the link ends. I've been there done that. Good Luck!
Old Nov 30, 2017 | 08:10 PM
I'm wondering if its the watts linkage myself or a snapped sway bar link. I had one snap on my D2 drove me nuts till I figured it out
Old Nov 30, 2017 | 10:42 PM
Alex_M's Avatar
If you can, or know someone who can do some lite fab work you can lower the front shock turrets like Alex_M did here > https://landroverforums.com/forum/di...rs-free-78143/
You can also make rear upper mounts that are lower than stock too.
Honestly, if you pay shipping both ways I'll shorten your towers for you for free, however much you want them shortened. Can't help with the rears from afar though, I'm afraid.
As for adding more weight than just steel bumpers... A winch Will add more weight, too, at least to the front.
Old Dec 1, 2017 | 01:43 PM
OverRover's Avatar
Alex, very cool of you to make the offer maybe satxpipe will take you up on it.
Good on you!
Old Dec 1, 2017 | 01:45 PM
JUKE179r's Avatar
I always thought these RTE adjustable front turrets where pretty bad *** for $170...
http://www.rte-fab.com/products?page...category_id=52
Alex_M's Avatar
Eh, I just try to help guys out on the forum. Plenty have helped me a bunch of times.
Plus, I love an excuse to weld!
disco202
Mar 22, 2021 10:06 AM
talltodd
Dec 7, 2015 08:25 AM
droptine77
Dec 31, 2012 10:30 PM
wheelgarage
May 10, 2012 11:39 PM
jdhuegel1
Mar 1, 2011 08:26 AM
