Terraform Shocks
Old Dec 30, 2019 | 11:59 AM
Craig Alexander Mackintosh's Avatar
8th Gear
Front and rear shocks were changed, the springs were the same ones I had all along, I just took them out to get powder coated along with my brake Calipers, because why not? I already had it jacked up and all apart to change the shocks.
Old Dec 30, 2019 | 12:09 PM
Motorhead1's Avatar
I think this is a case of "I didn't notice it sagging in the rear before I took the springs out and had them powder coated?" moment......You need new rear springs. Go with a set of Heavy OME, or ARB.
Old Dec 30, 2019 | 01:20 PM
Jason Feuerstein's Avatar
I think the question was, are you sure you didn't put the front springs in the back by accident?
Old Dec 30, 2019 | 03:27 PM
Motorhead1's Avatar
Ohhh, I didn't know that was even possible?
Old Dec 30, 2019 | 03:42 PM
redwhitekat's Avatar
oh it’s possible. I got the tf heavy duty springs and shocks for 2 inch lift and also the shock towers. Ride is solid I think the tf shock towers makes a big difference
Old Dec 30, 2019 | 05:56 PM
8th Gear
That could be the missing piece of the puzzle. I also added TF shock towers. So the front is higher pushing the back down I suppose. I’ll stick to my plan of adding spacers to the new dislocation cones I ordered which are also by TF. Just to be absolutely certain, the front springs should be taller than the tears right?
Old Dec 31, 2019 | 05:02 AM
I typically go by thickness; the thicker spring will be in back.
tango123
Feb 8, 2019 09:43 AM
KingKoopa
Jun 28, 2017 11:08 PM
gavone1976
Feb 13, 2012 07:05 AM
kae
Dec 9, 2010 02:12 PM
sayre05
Mar 25, 2008 09:40 AM
